Probably not an issue for others but just a-checking in case anyone else is seeing this.
Recently latency and loss values have dramatically changed:
But via cloudflare, all looks fine:
Checked a couple MX devices and didn't see those kind of results. My suggestion would be add the ISP DNS and see where you are with that, if you see issues also, then its probably time to call the ISP.
That's what I'm experiencing as well.
I just filed a ticket to AT&T.
AT&T DNS
Primary DNS: 68.94.156.1
Secondary DNS: 68.94.157.1
It seems to be isolated to the primary DNS, from what I can see.
I have started using the Umbrella DNS address of 208.67.222.222 and making it the default instead of 8.8.8.8
@jbright added that too, but it still seems strange that 8.8.8.8 has issues, is it me, is it AT&T fiber, is it Meraki.
Still unsure, AT&T sees no issues and I tend to think they're right since 1.1.1.1 shows no issues, an AT&T DNS shows no issues and the Umbrella DNS shows no issues.
So what is it then?
Here's my test with just my AT&T fiber, see if you can see which one of these things is not like the other.
As an update, AT&T sees an issue with 8.8.8.8 but has offered no solution other than it is a google issue, although 8.8.4.4 is fine and 8.8.8.8 via WAN 2 is fine.
@Aaron_Wilson and your coworker has AT&T fiber too.
So far my ticket has not yielded a response other than:
AT&T HAS UPDATED THE STATUS OF YOUR INCIDENT: THE AT&T NETWORK TEAM HAS RECEIVED THE TROUBLE REPORT AND HAS ASSIGNED A RESOURCE.
I was wondering if it is coal?
