Secure Connect POC / Evaluation / Portal
Dazza_wifi
Hello
Trying to get a feel for proving evaluations for clients looking at SC for business.
Is there an actual portal for Secure Connect aside from the MX portal integration?
Thanks in advance.
Darren Sinden
It would be good if trial licences and NFR licences were available (they are not).
Also a special warning - if you are quoting this up for a customer with an existing Umbrella portal it is cruical that you get Cisco to tie the quote to the customers existing Umbrella org - at that stage.  It can not be fixed at order time.
Otherwise a brand new Umbrella org gets spun up and you'll have to go through the whole licence migration process to get it moved from the new org to the actual org being used.
It is really painfull getting SecureConnect correctly quoted and ordered and deployed for existing Umbrella customers.
9 Replies 9
Gary_Geihsler1
Meraki Alumni (Retired)
Secure Connect is managed in the Meraki dashboard. partners have access to the Secure Connect v2 instant Demo in dcloud. There are other resources available to partners on SalesConnect. Do these satisfy what you are looking for?
Gary_Geihsler1
Trials of Secure Connect are available for customers, currently only Cisco employees can initiate a trial. Partner initiated trials are being worked on.
NFR purchases for partners are available for internal/lab use.
For quoting with customers that already have Umbrella, you should follow the partner facing ordering guide. You would create a change/modify quote in CCW and the existing Umbrella org is automatically provisioned at time of purchase. If you do not follow the change/modify process we can fix the issue but it takes extra work with your Cisco team.
I worked extensively with the team in my country - no one could find a way to start a trial.  Could you send me a message with the process for a Cisco employee to do this, as I would be interested in doing trials.  I will pass the process onto my local Cisco team.
Could you send me a message how to do this.  I spent 4 weeks trying to order NFR licences.  No one could find a process for being able to do this.  4 weeks!
Gary_Geihsler1
Any Cisco Account Manager or Solutions Engineer can start a Secure Connect trial. The process is laid out on the internal version of the SalesConnect site. The document is titled "Requesting a Secure Connect Trial".
NFR is the same process as any other NFR product. https://salesconnect.cisco.com/sc/s/simple-media?vtui__mediaId=a1m8c00000niSNZAA2
That is the process I tried using.  It is not available for SecureConnect SKUs.  As in, the discount is 0%.
Gary_Geihsler1
The process does work for NFR, we have dozens of partners with NFR licensing. Work with your Partner Account Manager if there are issues.
Dazza_wifi
Thanks Gary
So no trial or evaluation only simulated demonstrations for customers to see in a sandbox environment?
There are a few resources available on SC this is true but Im product management so drilling into lots of areas some of which dont touch sales or technical.
Darren Sinden
SahandC
Hi Dazza_wifi,
Good things come to those who ask 😉. Ask your Meraki sales rep for a Meraki MX & Secure Connect trial to see the full benefits of the solution - https://meraki.cisco.com/en-uk/form/contact/
When you get your hands on it, here's an implementation series I've been working on: https://www.youtube.com/playlist?list=PLOaVYwC_uLF6C_Rx5lEQzPFdWIwr-7AGV
