Hello.
I don't think there is a way, as already operated by APP. Because it is an APP operation with a low-priced product.
Meraki Go - GS Switch Ports - Cisco Meraki
Yes, with the higher models Cisco Meraki series. However, a separate license is required.
MS - Switches - Cisco Meraki
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
