- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
how do clients usually configure their meraki networks?
Hello, I am creating a tool using Meraki APIS, but since i am a software developer and I don't have many insights on network and usage of the solutions i would like to know a bit about the "real world" scenarios.
- Do clients have only one Network for each business? or it is really common to operate different networks for a same location? Are networks tied to a location?
- Do small business have various Networks?
- Do small business have different organizations?
I am trying to create a dashboard, where you select your network and start doing things with it. But I don't know If the real scenarios involve more than one network.
If somebody could tell me a bit how it is the real world configuration for a Meraki that would be awesome!
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
We're a small business with two main office locations, and 5 smaller office locations. It's all under 1 organization, but each location is its own network with site-to-site VPN setup so they all "talk" to eachother. I like having each location as its own network for troubleshooting purposes and not getting equipment at various locations mixed up.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That sounds really interesting rburch. It helps me understand the product better. If you were going to pay for something that gives superpowers to your meraki, i guess you would like one single account for all the organization, right?
And I guess that each network has different characteristics, like for example: one may not have MV sense camera, the other yes, .. (I don't know more examples)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That's right- each location might have different equipment (for example our main office has a whole slew of MX/MS/MR, while other locations just have an MX). If I were looking for something to better the dashboard, I would want it for the whole organization.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Is there any needs you have identified that you would like to have addressed? Relating to the dashboard or sofware integrations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
https://documentation.meraki.com/MX/Deployment_Guides/Branch_Network_Setup
Sadly there are a lot of things needed, An Acual VPN client, IPv6 support, Multicast, SSL inspection; but Meraki overall is a fantastic solution which works for about 85% of clients. They are also great at adding new features all the time and integrate with a lot of Cisco products (Umbrella, ICE/ACS, and I hope the resent DUO purchase will be added soon).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I would agree with rburch. Typically each physical location will be in their own network. Switches, APs, cameras at a single site will all be in the same network. The exception to this are the MX firewalls. If you are running layer 3 switches in an environment, the client tracking section of the Addressing and VLANs of the MX, will need to be set to "ip address - Use if there is a non-Meraki layer 3 device routing downstream end clients.". Even though it says "non-Meraki" I still set this to track by IP even if it is using a Meraki layer 3 switch per https://documentation.meraki.com/MX/Monitoring_and_Reporting/Client_Tracking_Options.
The reasoning for this is at a layer 3 hop, a layer 3 device will change the source mac address to that of itself. If you're tracking by mac address, then all you'll see is traffic coming/going to your switch.
Once you change the tracking to be by IP address, it requires you to put the MX in its own network.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I run the networks for a company that has 26 sites plus a test lab.
Each one of these is a separate network under the one organisation all connected via Site to Site VPN (with the exception of the test lab)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
