have 2 active VPNs sending and receiving traffic on a MX100
Carlos23
good morning I would like to know if I can have 2 VPNs active at the same time passing traffic on an
How would the configuration be to perform this step?
If you mean two VPNs between the same two VPN peers - no.  If you mean a VPN to one peer and another VPN to a different peer, yes.
If the VPNs are between MXs in the same org, follow this guide:
https://documentation.meraki.com/MX/Site-to-site_VPN/Meraki_Auto_VPN_-_Configuration_and_Troubleshoo...
If the two remote VPN peers are not Meraki, use this guide:
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-Site_VPN_Settings#Non-Meraki_VPN_peers
Note that in this case you can't route traffic from one VPN peer to another VPN peer.
8 Replies 8
DarrenOC
Hi @Carlos23 , what’s your setup here?  Are you using a Meraki MX at both ends of the VPN or are these non Meraki vpn peers?
Inderdeep
Carlos23
I mean to use a VPN going out through WAN 1 and another VPN going out through WAN 2 at the same time but both go to the same destination only through different ISPs
MarcP
Sounds like one device and two VPN tunnels (?). Yes, it is possible.
Carlos23
Me refiero a usar una VPN que sale a través de WAN 1 y otra VPN que sale a través de WAN 2 al mismo tiempo, pero ambas van al mismo destino solo a través de diferentes ISP. esto es lo que quiero hacer
Carlos23
No.  They have to be built to the primary interface.
