Tunnel is showing up but traffic not moving.
Shubh3738
Tunnel is showing up but traffic not moving through second ISP only.
through 1st ISP tunnel is connected properly.
6 Replies 6
Ryan_Miles
You should contact Meraki Support
kevinchow
What about your routing or network load balancing settings?
kevinchow
Sd-wan & traffic shaping > uplink configuration
WAN2 make sure is not 0
Sd-wan & traffic shaping > uplink selection
load balance enable
Are you taking about VPN tunnel or WAN?
Shubh3738
VPN Tunnel
Have you created any performance classes that affect which AutoVPN tunnel is used?
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
Have you got AutoVPN configured to load balance and use both ISPs?
If you take down the primary circuit, is the second circuit used?  Perhaps you only have it configured or failover.
