ChatGPT
Stanslas
ChatGPT
I would like to know if ChatGpT will be used for quick Troubleshooting problems?
I feel is ideal to give quick steps on how to resolves network issues.
BlakeRichardson
I would rather Google and trawl through forums / reddit for answers. I prefer to work things out myself unless I am on a time constraint and thats not practical.
8 Replies 8
I'm my opinion the best way is try to learning by your self.
I really hate ChatGPT.
Stanslas
True, thanks
Inderdeep
Not at this point as people are trying to find the useful things from it. It may give some good results but not always.
Regards/Inder
www.thenetworkdna.com
I've tried, and it consistently gives the wrong answers, but makes then sound correct,
Stanslas
I agree in many cases it is not accurate in its responses.
BlakeRichardson
Stanslas
For sure, firing up ones skill set needs to workout on your feet and win.
MerryAki
It depends on the language model you are using. Often the data is outdated, but old fashioned IPv4/6 or network layer troubleshooting might be feasible using ChatGPT V3.5/4
Anyway, I case you prefer human interaction: The community is great
