Tunnel is showing up but traffic not moving through second ISP only.
through 1st ISP tunnel is connected properly.
You should contact Meraki Support
What about your routing or network load balancing settings?
Sd-wan & traffic shaping > uplink configuration
WAN2 make sure is not 0
Sd-wan & traffic shaping > uplink selection
load balance enable
Are you taking about VPN tunnel or WAN?
VPN Tunnel
Have you created any performance classes that affect which AutoVPN tunnel is used?
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
Have you got AutoVPN configured to load balance and use both ISPs?
If you take down the primary circuit, is the second circuit used? Perhaps you only have it configured or failover.
