Search instead for
How many VPN sessions can vMX100 have ?
Dear, All
Now, I make design of NW using vMX100
Could you teach me how many site-to-site VPN sessions can vMX100 have?
# In datasheet, only 500Mbps throughput is written.
We’d like to make over 1000 VPNs, Can I?
Accepted Solutions
Re: How many VPN sessions can vMX100 have ?
Hi
I believe the vMX100 have the similar capabilities as a physical MX appliance
The following url on the Page No. 3 suggests upto 250 Max concurrent VPN tunnels.
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_mx_sizing_guide.pdf
Cheers
Ajit
ajitsnw@gmail.com
5 REPLIES 5
Hi
Cheers
Ajit
ajitsnw@gmail.com
As far as I know, vMX is sized equivalent to the regular MX100 as @AjitKumar suggests. Given then, 250 concurrent client VPN sessions is what you should shoot for as a max.
MRCUR | CMNO #12
Hi, all
Thank you for replying!
Do you know how I can have over 250 VPNs using vMX?
And if you have design guide of VMX, please share me.
You could try launching multiple instances of vMX in AWS. Sites 1 to 200 would go to vMX1, sites 201 to 400 would go to vMX2, etc.
Unfortunately there are no deployment guides for the vMX yet other than the deployment instructions here: https://documentation.meraki.com/MX-Z/Installation_Guides/vMX100_Setup_Guide_for_Microsoft_Azurehttps://documentation.meraki.com/MX-Z/Installation_Guides/vMX100_Setup_Guide_for_Amazon_AWS
As @kevinl mentioned, you can deploy multiple vMX appliances to scale the VPN connections.
MRCUR | CMNO #12
