What is the best practice for assigning group policies?
JMG
Just browsing
I am setting up a staff, guest and executive wi-fi network all on different VLAN's.
I'm interested to know if group policies are best assigned at SSID level (wi-fi bandwidth limit), the addressing and VLAN's section within security appliance, or in network-wide?
Many thanks in advance,
Jake
MRCUR
This KB article provides a good overview of the limitations of group policies based on product and how you can apply them: https://documentation.meraki.com/MX-Z/Group_Policies_and_Blacklisting/Creating_and_Applying_Group_Po...
Generally it comes down to what you want to do with the policies. If you're only assigning a VLAN through the policy that matters for WiFi users, you could apply them via MR SSID's and leave wired users going through the MX unaffected.
MRCUR | CMNO #12
Adam
If you just want to limit per client or per SSID bandwidth you can do that on the SSID without a policy.  Policies would be for more customized things like different content filters etc...  Or possibly bandwidth restrictions for a specific client.
I'm with @Adam.  If you just want to limit WiFi client speed then don't bother using group policies - do it on the SSID.
When I do use group policies I tend to apply them on the VLAN on the MX.  This is because the MX can apply many more types of restrictions.
