"View failed to load" error when selecting iOS apps
Stephen-aps
Meraki > System manager > manage > apps > change the platform to iOS select an app then it gives a “View failed to load” error message!
Note: If I change the Platform to Android to view our android apps it’s working correctly.
Is anyone else having this problem?
@Stephen-aps I just tried it myself and it is working as well. Even the Meraki support rep was confused as it was working for him as well. My guess is whatever change they made got undone or fixed.
5 REPLIES 5
vassallon
@Stephen-aps I'm having the same issue. Tried both Edge and Chrome and it appears like it will load the page and then crashes out to the view failed to load screen.
I have opened a support case and I'm waiting to hear back.
Thanks, at least I know it's not just me now. Hopefully they won't take too long to fix it.
I am having the same issue. I have just opened a support case, I am also getting an error when adding apps.
www.btr.net.nz
I had an email from support saying they were aware of the problem and were working on it; it seems to have started working again now for me.
"Hello,
There is currently a known issue regarding the iOS apps page. Our development team is working to get this resolved.
I will attach this case to the dev case and update you as soon as I have any updates.
Sorry for the inconvenience."
