free trials
merakichamp
free trials
hi team, i have questions
1. is systems manager 30 days trials fully supported?
2. does it have all configuration features?
and when now you buy the license is there anything additional that you will not find in the trials
7 Replies 7
Bettencourt
Fully supported, no hidden features, you get the same with the trial as when licensed.
merakichamp
aright thanks a lot for this
BlakeRichardson
@merakichamp I am guessing its not supported for two reasons
1. Maintain support coverage for paying customers
2. To stop free version uses signing up to a trial just to get support for an issue they are having.
merakichamp
 @BlakeRichardson  so its only support that will be missing but what of the features will someone be able to utilize all the features required?
Roska
feature set is 1:1 to a paid version, just buy it and you´ll have support deploying it, if you´re not happy you have 30 d of time to RMA lics if not suitable for you.
merakichamp
@Roska  ok this is great am asking all this because i want to be sure whether i go for trials or i just buy the license
BlakeRichardson
@merakichamp  I can't remember if there is a minimum requirement for license quantites but if there isn't why not just purchase a single license and go from there?
