Unable to enrol device
BlakeRichardson
I am trying to enrol and iPad after erashing it, its loaded in DEP but when get to the prompt to say the device will be managed by an MDM and i go to enter my Meraki credentials they don't work and I am getting "invalid network ID"
See attached image
Is anyone else having this issue?
BlakeRichardson
@R__S  Was connected using ethernet. I ended up restoring the iPad 3 times before I was able to get it working, not sure if it was an OS issue or just bad timing with my dashboard having an issue.
R__S
Hi Blake,
Is it connecting to a network? This sounds like it's not authenticating and if it has just been reset, would need to connect to a WiFi network to do that.
BlakeRichardson
Belgarioz
I am having the same issue.... It's been hours so far I am resetting, creating account in MDM and everythig else, but it's not working.
I'll keep you updated after this Nth reset
Update:
nothing, I have an invalid network ID and keep me asking for credentials. I sued several of them, but i am unable to authenticate
