- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Settings Deployment
Hi
Does anyone know if you deploy a profile with restrictions on to a ios that already has a default profile set up and install does it merge the two together or does it override one profile.
I need to make a restriction change to a few devices but I don't want the new settings policy to override any restrictions just add an extra couple but since it is not all our devices I can not change the default profile.
Many thanks in advance
- Labels:
iOS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
With Apple devices, they go to the most restrictive policies being applied to the device. I have multiple different setting packages to apply more restrictive policies to student devices.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If I remember rightly, you can deploy multiple overlapping profiles, in which case the most restrictive setting is applied.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you have multiple profiles scoped to a device each contains a Restrictions payload, the more "limiting" setting will take precedence, e.g. if you allow a service/setting in Profile A, but disallow it in Profile B and both profiles are installed on the device, the disallow from Profile B will take priority.
You'll need to use tags to properly scope the payload to the required devices.
