Remote Desktop with Agent 4.1.4
mikashharia
Hi
Since upgrading the agents from 3.7.1 to 4.1.4 i have unable to connect via the remote desktop feature.
I click on a device to connect to and it says
Stopping old server...Stopped.
Starting new server....
Error connecting: timeout connecting to agent proxy
Is anyone else experiencing the same and knows a fix?
Thank you,
I would consider rolling back as this bug had already been fixed previously and may have returned in the new version.
I also recommend opening a support case.
Systems Manager Agent Release Notes - Cisco Meraki Documentation
mikashharia
Thank you for your suggestion - ill roll back and open a support case as well
RSU21it
Yes.  See this on 3.7.0, 3.7.2 and 4.1.4.
