Hi all
I have some AR apps that require camera access, however when I have applied restrictions for users, the app does not prompt the user to allow access to the camera. Instead they get a blank screen telling them they have to go to Settings > Privacy > Camera > (app name) and allow it from there.
The issue is, because the prompt never appears initially during the app, the setting does not show up at all in settings, either via the suggested route or via the direct settings for the app (under ios settings).
Like this, because it never requests access, so it never appears here.
It should look like this
Once I removed all restrictions, I was then prompted to allow access to the camera (via the app). Because I was prompted, it then appeared in the privacy list like the screenshot above.
Strangely, in both screenshots you can see that PuppetPals HD has prompted for camera access even with restrictions on, so why one app can and another can't access the same prompt....
Is there a specific restriction causing the prompt not to appear? Any ideas?
This is affecting the following apps that I have deployed using VPP device assigned and licensed.
Does Not Prompt with Restrictions - Archaeology
Does Not Prompt with Restrictions - Ancient Egypt ActiveLens
Does Not Prompt with Restrictions - LGFL WW1 ActiveLens
Does Not Prompt with Restrictions - Maya ActiveLens
Does Prompt with Restrictions - Romans ActiveLens
Does Prompt with Restrictions - Significant People and Events
Thank you.
