Thanks for your reply,
I filtered out some of the columns for security however nothing changed last week, they are all in the school, connected to the same SSID as they have always been and the internet is working fine, they are able to access the internet outside of the school.
The screenshot also shows only 30, there are actually 75 iPads showing the same date and time last connected. All are on site and don't leave the school.
As previously stated, I reset one and that worked, another I connected to a 4G hotspot to see if the schools ISP/Firewall was blocking ports but it didn't communicate with meraki, even asking it for a Check-in. SystemsManager app on the iPad also reports to be compliant yet still fails to check in with the MDM.
