Hi @BrandonModdes and @ekramer ,
Thanks for discussing this issue in Meraki Community. If the command line tool from Device details page is not working, please consider to check if you can send commands to enrolled devices from "Systems Manager > Monitor > Command line" section. Please also consider to create a Meraki support case so that the Meraki support team can check if there's any ongoing issues reported for this feature and assist further.
Thank You,
Sabina
