Increasing MDM to more than 100 devices
Javy26
Good day,
Currently my MDM allows up to 100 devices. The business is growing and as such more devices are being added. How do I go about increasing the quota?
DarrenOC
Hi @Javy26 , this response from @PhilipDAth may help
https://community.meraki.com/t5/Mobile-Device-Management/MDM-Licensing/m-p/110171#M7828
10 Replies 10
DarrenOC
Hi @Javy26 , you literally buy more licenses 😁
Javy26
My bad, should have specified, been looking through the application where to buy. Do I send an email instead?
DarrenOC
Are you on the free subscription currently?
Are you working with a Cisco Partner?
Javy26
Yes but no Cisco Partner
DarrenOC
Hi @Javy26 , where are you located?
I should then be able to point you in the right direction?
Javy26
Jamaica
DarrenOC
Hi @Javy26
From what I can see there are three AMs covering Jamaica.  First one is Martin
rargueda@cisco.com
Might be worth dropping him a message asking which partner they can put you in touch with in your area.
Javy26
Perfect! Thank you @DarrenOC
DarrenOC
Inderdeep
@Javy26 : I guess you are using free 100 Licenses, above 100 you have to buy licenses and depends upon the devices you are gonna connect.
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
