How to remove old devices that are physically inaccessible anymore
Kanjiro
On our Meraki MDM dashboard we see a number of old devices that are physically inaccessible anymore.
We tried deleting them multiple times but they show up again after few days. Then we tried method described here https://documentation.meraki.com/SM/Device_Enrollment/Uninstalling_Systems_Manager_and_Removing_Mana... . But, still the devices come back.
How to remove them for good from MDM?
Many thanks!
1 Reply 1
ConnorL
Meraki Employee All-Star
Hello @Kanjiro ,
If you no longer have access to the device(s), you have two options:
  • Move the old devices to a new network, ensure they're checking in - then after 24hrs delete the new network. This should prevent the old devices from re-enrolling into the correct network as they will have updated their configuration with the new network ID
    • This does usually work, but sometimes if the device(s) aren't checking in regularly they may not update the network ID, if so, try the option below
  • Alternatively, move all existing SM devices to a new network (excluding the old ones you wish to remove)
    • You'll need to recreate your apps & configurations, so this may be a little destructive if you have a lot of them
Cheers,
Connor
