How can you disable Live Photos for iOS devivces from Systems Manager?
spiceheadjones
Just browsing
I have users that will be using a supervised iPad to take photos, and they will be transferring them to their desktop through USB. Live Photos are enabled by default, and they show up in the DCIM directory of the iPad as a .MOV file for each photo.
My users arent interested in the Live functionality, so it just adds extra noise that they need to parse through to locate the photos they're looking for, and additionally it complicates the copy-paste process, since they need to unselect the .MOV files.
So is there a way to disable Live photos completely?
I see I can disable it as a *default setting* by going to Settings > Camera > Preserve Settings > Live Photo, but I still need to go to the Camera app to disable it there, and my users can still accidentally re-enable it after that.
6 Replies 6
BlakeRichardson
@spiceheadjones Usually personalisation settings like these are not adjustable via an MDM. Having a google search for managed up settings should give you a clear answer hopefully.
spiceheadjones
Just browsing
Thanks for your reply @BlakeRichardson
A feature like this would be useful in a production environment, because the less opportunity there are for mistakes to occur, the better.
I may have them use the search bar in Windows Explorer to filter results by images only, if they wish to continue using the iPad for photos.
BlakeRichardson
@spiceheadjones This is a lack of feature support on Apple's end not Meraki just FYI.
ConnorL
Meraki Employee All-Star
If it's not listed here, then it's not supported by Apple and therefore something that cannot be changed by Meraki.
The only option that we have regarding MDM and the camera is disabling it:
So, unfortunately, disabling Live Photos is not something MDM can change. You can submit feedback to Apple via this website. If they ever implement this, you can be sure Meraki will allow this too 😀. If the main headache is that users have to deselect the .mov files, maybe search the folder for the .heic or .jpg files and then the .mov's will be hidden. Live Photos can come out awesomely too!
murielharris
Hey There,
To disable Live Photos on iOS devices managed by Systems Manager, you can utilize the camera settings within the device management profile. By adjusting the camera settings to disable Live Photos, users can take standard photos without the Live Photo feature enabled. This is particularly useful for users who frequently transfer photos to their desktops via USB, as Live Photos are saved as .MOV files alongside regular photos in the DCIM directory. For those interested in editing photos on iOS, visiting the App Store to download PicsArt can provide a comprehensive suite of editing tools and filters...Good.
murielharris
On iOS devices under Systems Manager control, you can use the camera settings in the device management profile to turn off Live Photos. Users can snap regular pictures without the Live Photo functionality active by modifying the camera settings to disable Live Photos. Because Live Photos are preserved in the DCIM directory alongside conventional photos as.MOV files, this is especially helpful for users who regularly transfer photos to their desktops via USB. If you want to edit images on iOS, you can get a full suite of editing tools and filters by downloading PicsArt from the App Store.... Alright.
