Multiple Profiles - How to Enroll a Device
SergioRodrigue
Good morning,
In the company I work for, we have several Android mobile devices, totalling 60 units. Not all of them need the same configuration, so I have created two profiles. The issue arises when enrolling a device, as it automatically adds to the default profile and does not allow me to choose the desired profile. Is there a way to enroll a device and specify which profile I want it to install? Currently, what I do is enroll with the default profile and then change the profile in the device settings later.
Thank you very much.
You can change the profile after the device has been enrolled.
https://documentation.meraki.com/SM/Profiles_and_Settings/Configuration_Profiles
In the past when I have had quite different device needs - I have actually created separate Systems Manager networks.  For example, BYOD and Corporate.  I find it makes some of the policies easier too.
Then you can use two different enrollment URLs/QR Codes, etc
SergioRodrigue
Hello. Thank you for your response.
