Has anyone deployed ESet agent via Meraki SM
Richard_W
As the Subject states. I have attempted to deploy the .pkg file to no avail, any help would be thankful.
PaulF
@Richard_W
Does the installer have any need for interaction from an end user? If so, you'll need to do some customisation.
Secondly, the other way to diagnose where the issue may lie is to try and install locally using the command line:
sudo installer -pkg package_name -target /
Change package_name for the name of your installer. If it installs fine, excellent, we'll try something else. If not, looking at your logs may help
Paul
BlakeRichardson
As Paul mentioned if you have simply downloaded the package from Eset and uploaded it to Meraki it won't work.
Often installers require user interaction such as typing in a serial number, API key or other information. If this is the case the automated installer doesn't know what to put into these fields
This is the agent from their console (as in pre-configured).
