Solved! Go to Solution.
Is the IOS device enrolled using supervised mode?
Only in supervised mode can you reliably get GPS info. Otherwise, IOS won't allow the Meraki app to get the GPS info unless the user allows it (even then, its not crash hot).
These BYOD devices aren't in supervised mode so pushing the Meraki app would be on the honor system which really means, why do it at all. 90% of the users won't click the app to even see the prompts to enable GPS and if they skip it, and have the app, they will be compliant anyway.
If there was a way in Meraki to lower the criteria to IP based location vs GPS, it would work but I don't see that happening without a feature change.
At this point it's just as easy to review the Map daily (as that does update based on IP) and then simply setup Apps to NOT have the following tags and then just manually tag the devices. That should trigger a removal based on a tag vs GPS location.
Just unfortunate you cannot simply lower the standards for Location Based Triggers
So, here's a thought: You get both LAN and WAN IP address via the API... It wouldn't take much coding to use the Devices API to get the IP address of every device, and set a tag based on compliancy against IP address.... It would save you having to do this through the UI, and means you could run it several times a day.... Let me know if this is something you'd consider...
Paul - Interesting because long story short... my Dir of Sec ended up using Okta Workflows to use the Meraki API to get the location, tag the device... circle back and check locations every 6 hours and tag again if they came back.. "outsideUSA" and "insideUSA".
It's been working very well minus an edge case which was solved.
We run this daily and can reasonably determine the locations of enrolled devices and Okta workflows make it nice to schedule and monitor.
