Export Inventory
Dion1
Export Inventory
we have around 50 networks of combined hardware is it possible to export this data for all networks?
i am looking for
  • Name
  • System Name
  • Serial Number
  • Make
  • Model
  • OS
  • Notes
At the moment the only way I can see to do this is to do it site by site.
Any other reporting would be great too
9 REPLIES 9
Is the API a option for you? Have you checked the organization inventory?
if it will give me some or of this yes
  • Name
  • System Name
  • Serial Number
  • Make
  • Model
  • OS
  • Notes
  • The information on organization inventory are not enough?
You can get most of this by going to Organisation/Inventory.  Then click on the spanner in the upper right hand corner and turn on some extra columns:
Then click "Download as CSV".
You wont be able to get notes.
Hi Philip, This is how i have been doing so but this can only be done on a network by network baces. i hoping to export a list for all networks at the same time.
Wrong, It's by organization.
Organisation/Inventory only shows the meraki Cameras not the combined hardware like iPads.
So, you want to export the client list.  In this case, the only option is via API.
https://developer.cisco.com/meraki/api/#!get-network-clients
You need to create a script to get it from each network.
PaulF
As others have mentioned, the API is probably the right way to do this.
# Meraki library : pip install meraki : https://developer.cisco.com/meraki/api/#/python/getting-started
import meraki
import logging, sys, getopt
loggingEnabled = True
def main(argv):
    print("Meraki Library version: ")
    print(meraki.__version__)
    arg_APIKey = "xxx"
    arg_orgID = "xxx"
    # Create Meraki Client Object and initialise
    client = meraki.DashboardAPI(api_key=arg_APIKey)
    # orgs = client.organizations.getOrganizations()
    # get Networks
    networks = client.organizations.getOrganizationNetworks(organizationId=arg_orgID)
    for network in networks:
        try:
            deviceList = client.sm.getNetworkSmDevices(networkId=network["id"])
        except meraki.APIError as e:
            print("Not an SM network")
        print(deviceList)
if __name__ == '__main__':
    main(sys.argv[1:])
You'll need three things for this to work:
  • The Meraki Library Installed.
  • Your Organization ID
  • Your API key
All of this is covered here: https://documentation.meraki.com/General_Administration/Other_Topics/Cisco_Meraki_Dashboard_API
The above script needs editing with the API key and the Organization ID, and will export to the interface all the details that you want.
The API does take optional extras:
def getNetworkSmDevices(self,
networkId: str,
total_pages: int = 1,
direction: str = 'next',
**kwargs: Any) -> Any
List the devices enrolled in an SM network with various specified fields and filters
https://developer.cisco.com/meraki/api-v1/#!get-network-sm-devices
networkId (string): (required)
total_pages (integer or string): use with perPage to get total results up to total_pages*perPage; -1 or "all" for all pages
direction (string): direction to paginate, either "next" (default) or "prev" page
fields (array): Additional fields that will be displayed for each device.
The default fields are: id, name, tags, ssid, wifiMac, osName, systemModel, uuid, and serialNumber. The additional fields are: ip, systemType, availableDeviceCapacity, kioskAppName, biosVersion, lastConnected, missingAppsCount, userSuppliedAddress, location, lastUser, ownerEmail, ownerUsername, osBuild, publicIp, phoneNumber, diskInfoJson, deviceCapacity, isManaged, hadMdm, isSupervised, meid, imei, iccid, simCarrierNetwork, cellularDataUsed, isHotspotEnabled, createdAt, batteryEstCharge, quarantined, avName, avRunning, asName, fwName, isRooted, loginRequired, screenLockEnabled, screenLockDelay, autoLoginDisabled, autoTags, hasMdm, hasDesktopAgent, diskEncryptionEnabled, hardwareEncryptionCaps, passCodeLock, usesHardwareKeystore, androidSecurityPatchVersion, and url.
wifiMacs (array): Filter devices by wifi mac(s).
serials (array): Filter devices by serial(s).
ids (array): Filter devices by id(s).
scope (array): Specify a scope (one of all, none, withAny, withAll, withoutAny, or withoutAll) and a set of tags.
perPage (integer): The number of entries per page returned. Acceptable range is 3 - 1000. Default is 1000.
startingAfter (string): A token used by the server to indicate the start of the page. Often this is a timestamp or an ID but it is not limited to those. This parameter should not be defined by client applications. The link for the first, last, prev, or next page in the HTTP Link header should define it.
endingBefore (string): A token used by the server to indicate the end of the page. Often this is a timestamp or an ID but it is not limited to those. This parameter should not be defined by client applications. The link for the first, last, prev, or next page in the HTTP Link header should define it.
