Apple have updated their MDM commands page with a new Managed Apple ID default domains command that's supported with iPadOS 16.1 however I can't seem to find this in the Systems Manager portal as a setting I can actually use
If this is unsupported at the moment, when is it likely Meraki will add support for this command?
Thanks.
