Enrollment profiles - Thank you
BlakeRichardson
Can I just say a quick thank you to the SM devs that have added the ability to remove unused enrolment profiles. I remember I asked about this 5-6 years ago and was told it wasn't possible but I've just discovered it and it now means I can have a clean out!
Thank you 👍
6 Replies 6
Tony-Sydney-AU
Meraki Employee All-Star
That's great news @BlakeRichardson !
The "Give your feedback" button in the dashboard works. It may take some time, but new features often come from people that took the time to do a Feature Request.
Fahfoofnik
Where exactly is this place to edit Enrollment Profiles? What is the exact path? I can easily see regular Profiles and Tags and I know how to edit those; but there is a support email address that is no longer in use in one of these Enrollment Profiles and after a pretty exhaustive search of this community and web/AI searches, I simply cannot find where to change the settings for Enrollment Profiles...which is quite frustrating.
Can anyone describe what the exact path is from within Systems Manager to access, remove, and edit Enrollment Profiles?
Fahfoofnik
This is what I mean. When I sync ADE, I search for the serial number of the iPad/iPhone. I find it; I select, click on Manage Profiles; I'm then shown a list where I can choose "Visible" or "All." I click on All, and I see all the enrollment profiles there...clicking on any of the 10 profiles, it would seem obvious to me that I would be offered a place to edit this specific profile I just clicked on, but there's no such option...I see what's below. At the bottom, there's an option to "Cancel" or just close that window. This is not helpful.
I need to edit these fields in this profile and others. Where does one go to edit these?
BlakeRichardson
I don't believe they can be edited, why I have no idea as other MDM products allow editing for this kind of enrolment setting.
Fahfoofnik
This is utterly ridiculous. What a shocking omission. This is hugely disappointing.
So how did you remove Enrollment Profiles?
BlakeRichardson
Under Systems Manager > ADE there should be Enrollment profiles as one of the option, click on that and you will get a list of the settings you have created with a delete button at the right hand side of the page.
