based on your documentation there is an ADE server name that should be visible on my dashboard,
above image attached based on your documentation
Apple ADE tokens last for one year by design. To continue enrolling via ADE:
In your Meraki Dashboard navigate to Organization > MDM. In the Apple ADE servers section, select the ADE server you would like to update by clicking on the pencil icon on the far right-hand side. This will pop up the Edit ADE Server window, inside the window press the blue Update Token.
We are able to update the MDM push certificate, however I'm unable to see where the apple ADE server is listed.
I do have devices on my ABM which is reflected under the Meraki ADE-, however I don't see a section to update a token if necessary.
would this be an inquiry for my rep, i'm also an admin in the acct
