@RobustMeraki If you are wanting an MDM to use with Apple products then they have to follow Apples standards.
Using something with reduced security is not a good idea, while it may fix a problem short term if are ever a victim of cyber attack that reduced security will be the weak link in your system potentially and a way in for hackers.
Customers need to know that things done properly cost. IT solutions implemented properly are not cheap and they never will be.
