Device names
Koops
Device names
Hi
I have set all device names in the MDM but all the iPads are still called iPad on the device.
Are you aloud spaces and - in the device names?
Also can you make the device name and serial show on the desktop.
BlakeRichardson
@Koops  you need to enable the below setting which is located under the restrictions payload located in Systems Manager > Settings
5 Replies 5
Inderdeep
Koops
Thanks for your advise but i have not fixed this yet and all my iPads are still named iPad.
Inderdeep
People changed the name of the ipads. Check this thread
https://community.meraki.com/t5/Mobile-Device-Management/Changing-System-Name-for-DEP-Enrolled-iPad-...
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
BlakeRichardson
Koops
Thanks I have this working now.
