Getting error messages stating laptop isn't supported, but I don't see any logs to pull. Any ideas?
Solved! Go to solution.
Do you get this error while trying to install the profile or the agent?
Also do you have enough SM licenses available?
Have you looked at this documentation as there are multiple way to enrol a Windows device.
https://documentation.meraki.com/SM/Device_Enrollment/Windows_Enrollment
Windows 11 with the latest patches. 2 different versions of Lenovo. One was a P14 and the other a P15
I have 5-10 licenses available. Will read link and try to see if that works.
I ended up going to the enroll.meraki.com and was able to load. Thanks.
What browser are you using? Mind sending over the full user agent? https://www.whatsmyua.info/
E.g. Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36
It will be next week till I get back to the office where the laptops are at. Will post then.
