Under Restrictions profile there is an "i" after the "Allow modification of passcode settings" option, which says that if you have a password policy set, then the setting has to be allowed. However, under https://documentation.meraki.com/SM/Profiles_and_Settings/Configuration_Settings, there is an informational box under the Passcode section, which says "If using this in conjunction with the 'Restrictions' payload for iOS, ensure that the 'Allow modification of passcode settings (iOS 9+)' option is not selected in restrictions."
My question is, whether I should allow the option or not, if we have a password policy set?
