This project aims to replace outdated 100 Mbps switches with Cisco Meraki MS225 & MS125 models while upgrading network racks for better cable management, airflow, and overall network performance.
That’s some transformation @Shubh3738. Well done
Beautifull.
Thanks Sir. @PhilipDAth @DarrenOC
@redsector Thankyou Sir
Want to join the conversation? Log in with your Cisco ID to comment. If you don't have one, sign up—it's quick and easy.
