Using Toast POS and can't change the ip address for the printers. I can't get them to be recognized by meraki router. POS tablets are working but the printers are offline??? The people at Toast are not helpful...Any help would be greatly appreciated.
Do you have a local reseller that supplied you the gear? I am not familiar with that POS so I don't know how to configure the gear but if you cannot set its IP's address thats not really a Meraki issue.
Toast supplied the gear and they have been useless...Just figured out it is not the IP address. I'm able to change that now but it still says they are offline. Frustrating...
@nhb333 I suspect you might need to hire an MSP to give you a hand, trying to resolve your issue isn't going to be easy as you haven't really shared much information that we can use to help.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_676d1b524baa27","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_676d1b524baa27_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_676d1b524baa27_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_676d1b524baa27_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_676d1b46d60968","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
