Is it possible to link devices from SFP to SFP+ ports?
Eds89
We have an MX84 appliance, which has SFP ports.
Is it possible to create a downlink to a device that has SFP+ ports?
As I understand it, SFP modules work in SFP+ ports, so would we use SFP modules on both ends, or would the SFP+ device need an SFP+ module?
My assumption is the transceivers need to be the same so I'd run 1Gb SFP modules in both ends?
Cheers
Eds
You need sfp module on both ends
Inderdeep
@Eds89 : Either to have SFP on both sides or SFP+
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
RestaurantGuy
To be upfront, I have not tried this.
But based on how the devices work and how the hardware usually works in regards to SFP adapters, you have to match the SFP/SFP+ to the port it is installed in.  That said, you should be able to cable the fiber between the two and run at 1GB speeds, the lowest common denominator.
