Is there a known reason why most of the RSTP traffic is correctly recognised, but a good chunk is not?
Is there anything I can do to make it recognise all of the traffic?
I've got the same problem, I'm guessing thats CCTV traffic.
@BlakeRichardson yes, absolutely right, we have lots and only some gets recognised and the rest fills most of the rest of the top 10...
Let's wait for NBAR coming to MX too... 😐
Yes NBAR!!
I remember a Jeremy Cioara video from years back where he was like "NBAR!! on a switch!! drool!
But at that time that just wasn't possible 🙂
I have an MX84, MR36 and MS210 in my home Lab. From what I have read, I believe the problem in my case is my switch MS210.
I think the minimum requirement for NBAR in combined network for the Switch is MS 390. Does anyone know if this will be available for MS 210 series?
Regards,
@JimmyM, if you haven’t seen this document already have a look, https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Network-Based_Applica.... It doesn’t appear to indicate a restriction on the MS in a combined network, but I do get where you are coming from. It seems to suggest you can run MS12+ in a network with Wifi6 MR27+ access points and MX16+ device, and still get NBAR working. If it doesn’t it might be worth opening a case with support, there might be something stopping it that they can see.
