System Manager....evolution...?
Android evolves on new enrollement, owner mode and and Work/personnal profile.....
It will available on meraki ?
corporate-owned, personally enabled (COPE)
https://developers.google.com/android/work/terminology#fully_managed_device_with_a_work_profile
Fully managed devices with work profiles are for company-owned devices that are used for both work and personal purposes. The organization still manages the entire device. However, the separation of work data and apps into a work profile allows organizations to enforce two separate sets of policies. For example:
  • A stronger set of policies for the work profile that applies to all work apps and data.
  • A more lightweight set of policies for the personal profile that applies to the user's personal apps and data.
2 REPLIES 2
Re: System Manager....evolution...?
Hey Alex,
Systems Manager does not currently support this configuration for Android Enterprise. Currently supported configurations include full Device Owner mode or BYOD work profile mode (not fully managed). You can read more here: https://documentation.meraki.com/SM/Device_Enrollment/Android_Enrollment
We appreciate your feedback and are always interested in hearing what features and functionality our users are interested in. Were you just curious or actively planning on using this Android feature? If yes, can you tell us more about how and why you were going to use this in your organization?
Thanks,
Victor Mach
Product Management, Meraki SM
Hello, thank's for this return, yes in France generally the society provide the smarthpone, so we are not in Byod profil.....and we don't want block the google play....but control terminal (factory reset.., usb....)
So we are interested for a Businness Smartphone, owned by the company but i can use personal applications.....
Owner mode with personaly profil enabled 😉
