Search instead for
SM's Cellular Data Usage Reporting - Limitations
Has anyone recently noticed limitations on the reporting of SM's Cellular Data Usage?
For example here is the latest snapshot of an iOS device over the last 3 months;
Past_3_Months.PNGPast 3 months data usageWhilst here is the graph report for the last month;
Past_Month.PNGPast month data usageSurely there should be graph data displayed during September visible in the top graph "past 3 months" to display in the above graph for the month?
Needless to say there are no graphs for either "past Week" or "past Day" either.
Accepted Solutions
Re: SM's Cellular Data Usage Reporting - Limitations
I would say there is a bug, I have seen similar things with a different graph, I cant remember what it was for but I had the same issue you were having about a week ago.
2 REPLIES 2
Same here.
