getOrganizationApplianceVpnStats missing data
JGill
Anyone notice a change in the data retuned by
https://developer.cisco.com/meraki/api-v1/get-organization-appliance-vpn-stats/
The Latency,  Loss and Jitter elements are missing.  Just shows usage data.
Mloraditch
I just did a test on a couple of orgs. One on shard 874 worked fine, one on 97 got what you are seeing. I would open a support case.
MartinS
I've just looked over our install base (we're collecting data from 10,000+ devices for this metric) and I'm not seeing anything broken here. Note that Meraki only collects that data if the local or remote devices have 2 WAN interfaces - if you're running a VPN between two devices with a single WAN on each Meraki won't run that test unless you contact support and tell them to turn it on.
COO
Highlight - Service Observability Platform
www.highlight.net
JGill
At some point they corrected the issue last night/early this morning.  We had stopped our log process so don't have the exact times, but all our VPN stats are back to normal.
KunalKonduru
Hi @JGill,
In case you are still facing issues with the GET API call not returning all the elements, I would recommend you to call into our support hotline/open a case, so that our engineers can help you troubleshoot the issue.
