- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Terraform Crashes 0.2.13-alpha
Does anyone else have experience of using the Meraki Terraform provider with the Meraki Dashboard and it frequently crashing? I am using the latest version 0.2.13-alpha and configuring switches and ports. Most of the time I have to run Terraform apply 4 or 5 times for all the switch ports to be configured on just 2 x 48 port switch stack. If anyone knows of this issue or any workarounds I'd love to hear from you.
Stack trace from the terraform-provider-meraki_v0.2.13-alpha plugin:
fatal error: concurrent map writes
Error: The terraform-provider-meraki_v0.2.13-alpha plugin crashed!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hmm, I suspect this may be due to making concurrent changes to switchports within the same stack.
We "lock" a stack during a change via API to ensure that whatever changes are being made don't write over each other in a race condition, which can cause issues if you're running simulations batches that edit the same stack. Might be worth opening a Support ticket for this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for replying, I am definitely making concurrent changes to switchports with the same stack. For example:
