Extract IP ranges from dashboard
Irvin_Maharaj
How do i extract a list of all IP ranges configured on the dashboard ?
Can i use a api and how will this work ?
2 Replies 2
jimmyt234
What exactly do you mean by "all IP ranges configured on the dashboard" ?
Messy
If you are talking about VLANs, yes you can use the API, the specific endpoint will depend if you have configured the VLANs on switches or MX's
