How can I find based on a switch serial if it is assigned to a switch profile
RaresPauna
Hello guys, i tried a workaround today with this call
this call should return that profile parameter which shows the id of the switch profile. The problem is that running this call in postman/ script , with the latest api, is not returning that profile attribute, even if the switch is 100% assigned to a switch profile. Am I doing something wrong ? Is there other way to list the association between switches and switch profiles ? Thanks
LearningIsFun
I’m pretty sure the profile you are looking at there is the security profile for the port, not the switch.
I take that back. Think I’m wrong there.
rhbirkelund
If you use the Get Device Endpoint, does it return the switchProfileId?
RHB@wopr ~ % curl -L --request GET \
--url https://api.meraki.com/api/v1/devices/<serial> \
--header 'Authorization: Bearer xxx' \
--header 'Accept: application/json'
{"lat":nn,"lng":nn,"address":"","serial":"","mac":"34:56:fe","lanIp":"192.168.128.4","url":"","networkId":"","tags":[],"name":"Home-MS120-8LP","details":[],"model":"MS120-8LP","switchProfileId":null,"firmware":"switch-16-7-1","floorPlanId":""}
