- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Bulk renaming of APs through Postman Runner fails
I’m trying to do a bulk rename of APs in Postman. I have Postman set up with the following variables
And they work, so if I do any of the following, I get the expected output
GET {{baseUrl}}/organizations
GET {{baseUrl}}/organizations/:organizationId/networks
GET {{baseUrl}}/organizations/:organizationId/devices
GET {{baseUrl}}/networks/:networkId/devices
GET {{baseUrl}}/networks/:networkId/wireless/ssids/
So now I want to use runner, so I created a CSV file called “name-change-data” with a header line and a single line relating to a single AP I want to test on
The serial number is the number seen in the Meraki Dashboard, so I know that is right, and the name is just a different string to what is there at the moment.
I then create a collection called “Bulk Rename APs” that looks like this:
{{baseUrl}}/networks/{{networkId}}/devices/{{serial}}
the format of which was as specified in https://community.meraki.com/t5/Wireless/Rename-AP-with-postman-runner/m-p/21137#M3507
Next, I set up the body section as follows:
"name": "{{name}}",
"serial": "{{serial}}"
I then go to file>New Runner Tab, and get a window that asks me to “Drag a collection from the sidebar to run”, so I drag “Bulk Rename APs” in. It goes in with a lot of others, so I deselect all of them and reselect “Bulk Rename APs”
On the right of the page, I click “Select File” and select “name-change-data.csv” and then click the “run” button. I get the following result:
And the console shows
What am I doing wrong, and why is github flagged?
All advice gratefully recieved!
Roo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Your CSV format appears to be incorrect, please try the following.
serial,name ABC123456789,New AP Name
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I tried changing the CSV format, and this time read it in notepad to be sure I wasn't missing something. It now looks like this (X's to replace real data):
serial,name
Q5AXXXXXXUE,HQ-PMDF-AP999
so as you can see, the format now matches your example. I tried again to change the AP name and got the following:
and the consoles said this:
so I'm still doing something wrong..
Roo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It's not exactly the same error, but maybe it will help you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It might be interesting to open a discussion in the Postman community.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Take a look at this: https://learning.postman.com/docs/collections/running-collections/working-with-data-files/
