I never tryed that. But i think that should match what vlans you want to use, else it would start using "all" but limited to the first 1000
This is what the documentations says:
Active VLANs
Active VLANs are those that are actually instantiated on the switch, in the case of Catalyst switches. The Active VLAN list should match the required VLANs in order for the switch to function properly. The VLAN database function will attempt to prevent required VLANs from being removed from the Active VLANs list but cannot prevent all misconfigurations. When a misconfiguration happens, such as a switch management VLAN (a required VLAN) being removed from an Active VLAN list, the VLAN database will generate an alert on the details page for the affected switch(es).
