I have a ton of experience with iPad/DEP deployment because 99% of my clients use DEP apple iPads, however I have one client that uses Samsung Android Tablets.
Model: SM-T727V
Android version: 10
Knox Version: 3.5
I was trying to enroll these devices using the Owner Mode so that we could have full control over these tablets. We have enrolled the MDM with Android Enterprise using a Google Workspace (G-suite) Domain and enabled the Third Party integration on the G-suite side.
I am able to successfully enroll the tablets to the MDM via Add Devices in System Manager. However I do not seem to have the ability to Auto install apps or Push apps to the tablet. I did notice that when the activity log for the tablet said "install Success" I would see that the app had been added to the SM App on the tablet with a button that says install.
Questions:
- Does Android not let you install apps via the MDM portal?
- Do you have to have a user manually click install on the SM app?
- Could Knox be interfering? I did not enroll the device using Knox. (That I know of)
I guess I am having a hard time understanding the documentation with regards to Owner Mode and Android Enterprise. I called Meraki support but they just seem to be dazed and confused.
