- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Blocking apps android devices
Hello
I couldn't find a way to block applications on android devices that user can't install them at first place.
The only solution i found was the alert report if user install app which is blacklisted.
best
reimpsel
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @reimpsel,
If you're looking to prevent users from installing applications on their own, you can do so from the "Restrictions" payload within a configuration profile. Under the "Cross Platform Restrictions" within that payload, you'll see an option under device functionality "Allow installing apps" which if unchecked, will prevent users from installing unwanted applications.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @reimpsel,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello!
I tried it but it wont work.
1) Did a change in restriction where diallowed installing application.
2) Then made a policy rule to allow only Skype application to install.
3) In device detail i see infomration like that
And at then end. I still can easily install any other app like IG, FB messenger, FB, Snapchat etc.
I just dont get it what am i missing.
