Static IP Assignment via Dashboard
Has the Static IP assignment via the Meraki Dashboard moved out of beta? If it has not how reliable is it. I am moving an MX-64 from DHCP to static, however I am in Chicago and the router is in LA. Doing this remotely would save a lot of headaches.
Accepted Solutions
Re: Static IP Assignment via Dashboard
Identical.  Only thing I don't believe you can control is the duplex if for some reason you need to change that.  If you do, I think you still have to do that from the local config page.  Also, the device has to be online and checked in for you to be able to IP config via dashboard.  So that poses an issue for some people that have static IPs since they cannot initially connect the device to get it online.
6 REPLIES 6
Yes it is in production now and is accessible from the dashboard.  Security Appliance>Appliance Status then click the Uplink tab and click the little pencil next to the WAN interface.
It works just as good as doing a local IP assignment?
Yes it's on DHCP and I'm switching to static. However I'm not sure what you mean by checked in.
As long as it can get DHCP initially to get to the internet so it can check-in with the Meraki dashboard then you should be fine.  That will let it be managed.  At that point you could assign it the static IP from the dashboard and it should take.
Thanks for the info.
