SAML with Okta
Nik1
SAML with Okta
we have multiple orgs within meraki hosted in different parts of the world (from meraki cloud perspective). Each org has an unique consumer URL that is generated for the shared SHA fingerprint (from okta). Is there a way to tie all the regions together either via okta or Meraki? Thank you for your help
Nik1
FIX:
If you have the same SAML admin role (example: XYZ_TEST) across all the organizations. The MSP portal pulls in all the Orgs that the SAML authenticated user has access to. I can confirm this works with okta now.
NolanHerring
I don't see any way of doing this via OKTA, and since the URL's are coming from Meraki side, I would imagine it would have to be something on the Meraki side to be able to pull this off.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
Nik1
Thanks for a response, meraki handles it via saml admin role across all orgs.
Nik1
FIX:
