More Android app display issues
Launch the app, go to Devices, select 2 hours as the time-frame and go back to home and I repeatedly get this:
Note how the timespan is chopped to the length of the default PAST DAY, not sure why the delimiter for the devices frame moves up, but it is a consistent behaviour for me.
Anyone else see these issues?
6 REPLIES 6
UCcert
Re: More Android app display issues
Do you want an iPhone Charles? 😂
Darren O'Connor | uccert.co.uk
BlakeRichardson
@cmr  What model of android device is it?  I wonder if it doesn't support a high enough resolution.
Samsung S9+ with resolution as below:
I tried it at 2220x1080 (the next resolution down) and it is exactly the same.
BlakeRichardson
Yeah I would have thought thats more than enough. I'm guessing its just a software bug, I don't have an Android device to confirm this though.
Roy
It does that once in while on my Mi Mix 3 - but if I close and open the app it sorts itself out.
The main display problem I have is when I look at the uplink tab the page flashes up for a fraction of a second then the page goes blank apart from edit and the bottom menu.
