Meraki Logs polled while the device is restarted
RabbaniSyed
Just browsing
I am new to Meraki and would like to know is there any way to find when the Meraki MX is restarted in the Logs
There is not a specific log to know It was restarted, but you can configure an alert to it when goes offline or you can check the connectivity history on Appliance status page.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Alerts_and_Notificati...
5 Replies 5
Thanks for the Link but interestingly, I looked in the event log and noticed the following
When i query that no results are displayed...
It's under Monitor Appliance Status
Pavithran
We don't the option in Meraki Dashboard. May be Meraki support can give you the uptime of the devices.
Crocker
Support can poll the device uptime. Alternatively, you can look through the event log for "Ethernet port carrier change" messages for all of the connected interfaces. For example, when I see that message for ports 1, 2, 3 (we generally don't connect anything to 4 & 5) all with the same timestamp, I know the device rebooted.
